Car Just died
John77
E200 Estate 2011, 2009 SLK 200
Hi I had been out in the car for about half an hour and I went to turn right into my road. I stopped to let traffic pass and then when accelerating away the car just cut out and ran to a stop. It did immediately restart and this has not happened before, but I just wondered if this was a sign of something that may become serious. Any ideas?
2005 Eclass Estate.
Ideally you need the ECU codes read. It could be a crank position sensor beginning to fail or any one of several other things.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Petrol or diesel ?
Botus
S500/2010/500
Auto or manual ?
far easier to notice on a manual if the idle is bad / or low on power at the bottom, I'd suggest CPS but could be a air leak / breather system issue
mileage, service history, condition, info about the car and we might have more of an idea
John77
Auto or manual ?
Hi yes I will look at the fault codes later.
It is an E200 Petrol, Auto,
John77
Like others the best thing to do is get the Codes read, but crank position sensor comes to mind aswell.
Well plugged into icar soft and under ME SF Motor electronics it has
P200a-000
P2029-000
P201c-000
P205b-000
but it also says not in libruary, so no explanation of what the are. No other relevent codes in any other section.
John77
P200a-000
P2029-000
P201c-000
P205b-000
Having looked these up online, it says.
If your OBD II equipped vehicle has stored a code P200A, it means that the powertrain control module (PCM) has detected a problem with the intake manifold runner control (IMRC) system. Code P200A applies explicitly to the bank of the engine that contains the number one cylinder.
A code P2029, it means that the powertrain control module (PCM) has detected a malfunction in the auxiliary or fuel fired heater system that has resulted in deactivation. This type of code is applicable to vehicles with fuel fired heater systems only.
Code P201c-000 seems to have a few different explanations.
A stored code P205B means that the powertrain control module (PCM) has detected an abnormal degree of voltage in the reductant tank temperature sensor circuit. This code is exhibited in vehicles with a clean burning diesel engine, exclusively.
***But my car is petrol***
Botus
S500/2010/500
the joy of codes - here's a list relating to the ones you mention, I built up years back
codes Mercedes-Benz Fault Code List
P200A Knock sensor system of control module N3/10 (ME-SFI control module),Hardware fault
P200A ? [1] M16/6 (throttle valve actuator) Actual value potentiometer ,: First initialization
P200A ? [2] M16/6 (throttle valve actuator) Actual value potentiometer ,: Position Emergency running
P200A ? [4] M16/6 (throttle valve actuator) Actual value potentiometer ,: Adaptation Emergency running
P200A ? [8] M16/6 (throttle valve actuator) Actual value potentiometer ,: N3/10 (ME-SFI control module)
P200A Component N15/3(ETC control module) is faulty.
P200A-001 M16/6 (throttle valve regulation part) practical potentiometer,not initialization
P200A-002 M16/6 (throttle valve regulation part) practical potentiometer,position urgency start
P200A-004 M16/6 (throttle valve regulation part) practical potentiometer,adaptation urgency start
P200A-008 M16/6 (throttle valve regulation part) practical potentiometer,N3/10 (ME controller)
P2029 check S40/4 (button type switch TPM with variable speed limit).Closed
P2029 check S40/4 (button type switch TPM with variable speed limit).Negative acceleration limit
P2029 check S40/4 (button type switch TPM with variable speed limit).Positive acceleration limit
P2029 right cylinder bank camshaft adjustment (work link)(P0340)
P2029-001 engine RPM signal,error
P205B cylinder 8 misfire,CAT damageed (P0308)
And that's why a Star session is always best...
P200a-000
P2029-000
P201c-000
P205b-000
Did you correctly select your vehicle?
John77
Of course. In 2005/6 there was a change, but I selected mine, b ut still a good point.
John77
Well 3 weeks on and it has not happened again yet. Strange.
