Car "wiggle"
ssheikh93
London
W213 E220d
Any idea why my car "wiggles" over every pothole, bump, drain etc. From around 30mph on wards. Fairly new tyres.
W213 E class
worldbiker
London
1996 SL320
Incorrect tyre pressures?
Uneven tyre pressure (different tyre pressure on same axle)
Suspension bushes worn?
Steering bushes worn?
00slk
Cambridgeshire UK
2002 SL55 AMG, 2005 E320 CDi,
Agree with the top, add wheel alignment to the list front and rear ;)
How big are the wheels / tyres?
How cold is the road surface?
Craiglxviii
Cambs UK
More scarily (this happened to me!)- have you checked the tightness of your wheel bolts?
ssheikh93
London
W213 E220d
Don't know why I didn't check my pressure as I usually do. Was significantly low. Now seems fine and also straightened my steering wheel.
Thanks all.
mioba
Nottingham and Köln
Tyre pressure every couple of weeks check.
Lets one note if there are any leaks, untoward pressure drops.
ssheikh93
London
W213 E220d
Update: even though my tyre pressures are correct now, seems to still "wiggle". Was only able to tell as I drove at faster speeds.
Craiglxviii
Cambs UK
Have you checked your wheel bolts?
malcolm E53 AMG
Does your car have a staggered wheel set-up ie wider wheels on the back if so check that you have the narrower section wheels on the front, they do and can get mixed up
Craiglxviii
Cambs UK
Tyres mounted the wrong way? They usually have an Outside edge clearly marked.
