Car won't start .. top suspects?
Conor
London, UK
Morning chaps
So I was chatting to an old school friend the other day who has a W203 C-Class which will no longer start.
I'm just curious as to what it could be. I asked the usual suspects and he says he has fully battery, i.e. lights and all electrics work fine no problem. So alternator would seem ok?
I then said starter and he just said no..strangely. But he did say you could here a clicking sound in the engine bay (that he said didn't sound like starter)....so I thought relay, that may be clicking, but not closing the circuit...?
So.. my thoughts are:
- Bad earth
- Starter is gone and needs rebuilt.
- Relay is broke
- Ignition module/key switch (unlikely given symptoms..?)
- Some other fault in an ECU that needs STAR to guide us.
- It's not even cranking so fuel and stuff isn't even a consideration right?
...My money is on starter. Under what circumstances can you jump the starter points or is that cowboy? I saw a guy do with a forklift before and seemed a neat trick.
He fancies scrapping the car as it's not worth fixing. And I like a challenge. (Be careful what you wish for, eh!?)
Thank you
jays705
Harrow
E350 CGI
Hi Conor
I'd go with starter but best to get diagnostics for codes
jay
M80
Derbyshire
Short the heavy duty connections on the starter solenoid to see if it spins.
ajlsl600
france
As above. Bypass coil. If starts go look relay and coil
Conor
Conor
London, UK
Thanks everybody..
Yea, i'll plug it in first anyway and give the starter jump a go.
Cheers.
Conor
Conor
Conor
London, UK
Thanks all. Gave the starter a few knocks when starting and it fired right up.
Going to get refurbed now.
Cheers
brandwooddixon
Wolverhampton
S63 Coupe 2014
Common starter issue - glad you found it. Solenoid to throw the drive gear onto the flywheel fails or sticks (light tap with a hammer often frees it). Unless the gear is fully engaged the main coils aren't energised to turn the motor.
