Car wont start!
SmartAmg
2011 E class coupe 350 CDI
My C207 wouldn't start this morning. The problem started last night, when driving home the amber temperature warning light came on and the fan kicked in. So left it overnight and checked the coolant level this morning and that was fine, but it seems the fan had been going off intermittently all night and still is. Tried to start the car, it's totally dead. I'll phone my indie when he opens later, but in the meantime, any idea's? :(
ajlsl600
france
Sounds like faulty sensor telling ecm to run fan. Tho why that would not time out when key is not in ignition is somewhat beyond me.
You haven’t blocked scuttle drains and water into a SAM have you?
SmartAmg
SmartAmg
Sorry, Russ what do you mean? :oops:
Open the bonnet look below the windscreen and see if there's water pooling below the bonnet hinges - if so clear it out - there's drains in the bottom that fill with leaves and other detritus, this water build up then gets into places it shouldn't SAM (Signal Acquisition Module) is common, these control many car functions and adding water means things do strange things.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
What was the temp guage reading when the warning light come on ?
onefortheroad
uk.
Id agree with this and the sensor has somehow bridged itself at the connections or internally causing it to run on. We purposely used to do this with some wire, back in the day to keep the temperature down in hot summers if the fan wouldn't kick in.
I've also read about the Aircon pressure sensor failing ,causing it's fan to run on also.
SmartAmg
SmartAmg
Update, went to my indie, he said it sounds like the battery, so 1st thing charge the battery up, so I've bought a battery charger, I'll put it on charge and see if will start tommorow, then take it back to my indie to have a further look. :)
This is very soon after your oil cooler seal job buddy .
SmartAmg
SmartAmg
I know, Wighty, I'm presuming it's coincidence, I don't know how old the battery is, must admit as much as I love the car, this last 12 months has tried my patience a tad. :rolleyes::)
There should be a date stamp on one of the battery terminals
Manc Rick
Manchester
W213 E220 Premium +, 2017 with OM654.
Sounds like he/she/they think(s) that the fan running constantly has flattened the battery, preventing the car from starting this morning, which is completely plausible.
Hope they manage you sort the problem easily when you take it in. Cars hey… ood ‘ave ‘em
onefortheroad
uk.
Isn't that everyones thought ?
I'd be more concerned about the warning light and the fan running on its own ,seeing as the car was running at the time and the battery would of been charging.
SmartAmg
SmartAmg
Put the new charger on, the fan has started, it goes for 5 secs then stops, then goes for 5 secs then stops and so forth, I'll leave it charging overnight and see were we are tommorow morning, hope it starts.
Any water in the scuttle drains?
Manc Rick
Manchester
Put the new charger on, the fan has started, it goes for 5 secs then stops, then goes for 5 secs then stops and so forth, I'll leave it charging overnight and see were we are tommorow morning, hope it starts. @onefortheroad
I think it will start in the morning, but like @onefortheroad, I’d get it in so that the indie can try to get to the bottom of the underlying problem.
mioba
Nottingham and Köln
of course your battery will be flat if its running a fan all night. I guess you battery ran out juice eventually running a faulty fan. Why didnt you charge your current battery?
onefortheroad
uk.
He is .
