Carfax Needed Wdb126037a036104
mespe
Hi can anyone help me with a carfax for this vin?
pascal
near Dublin
sl320/1999/3.2
You are missing a part of the code, But:
Is it a black 500SEL with air-con, electric orto seats, sunroof (83-84) M117 engine? etc etc
Has a very high spec. Embasey car?
MB partsman
Silicon Valley
digit missing....
the digit missing is either... 1 or 2... or very unlikely a 6
this is the way vin numbers are read.....
WBD 202 028 2F 123456 1
WBD country code
202 basic model / chassis type
028 sub model / engine size
2 1=LHD 2=RHD 6=knock down kit (assembled from a kit)
F assembly plant
123456 unique id
1 warranty check digit
this is a basic breakdown... and it has changed a bit over the years...
ie the 2F was once 2 numbers 22 rhd/auto
20 rhd/manual
and in the 50's.........
xxx 043 35 12345 <note only 5 numbers in unique id
35 reverse to make 1953 build year /45 = 1954 etc
pascal
near Dublin
sl320/1999/3.2
That is why I thought it was a embasy car.
But MB Partsman, mespe hasn't been back and I couldn't find it in RHD:
Very High Spec?
VINWDB1260371A036104Model500 SELChassis1260371A036104
Engine117963 12 041467
Transmission722311 02 450861
Order0 3 229 07602
Approx. year1983
DealerStuttgart branch (229)
InteriorUnknown code (955)
Paint040black (T) (с 01.01.1963)
Options
221left front seat, electrically adjustable (с 01.11.197:cool:
222right front seat, electrically adjustable (с 01.11.197:cool:
223Model 126: rear seat bench electric adjustment (с 01.05.1977 по 30.06.1991)
406single seat with orthopaedic front seat backrest, left and right (с 01.07.1970)
410electric sliding roof (с 01.03.1965 по 29.02.198:cool:
430headrests in the rear (с 01.01.1977)
444tempomat (cruise control) and airbag (с 01.02.1980 по 31.10.1993)
452two-tone horn (с 01.01.1963 по 28.02.1993)
487hydropneumatic spring suspension all around (с 01.11.1978 по 31.08.1986)
504outside rear view mirror, right, electrically adjustable (с 01.11.1978 по 29.02.1986)
outside rear view mirror, right, electrically adjustable (l.h.d.)
taxi version, f.r.g, and outside rear view mirror on the right
510Becker radio Mexico cassette full stereo, electronic, Kurier LW/MW/SW/USW (с 01.09.1979 по 30.11.1990)
100%1570581automatic climate control (с 01.01.1977)
590heat-insulating glass, all-around, heated rear window pane (laminated glass), Germany
green heat-insulating glass all round, heated rear window, laminated safety glass - Germany (с 01.01.1972)
600headlamp wiper/washer (с 01.08.1971)
611courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.197:cool:
673high-capacity battery (с 01.01.1964)
682fire extinguisher (с 01.04.1970)
731wood trim, burred walnut root (с 01.08.1980)
877reading lamp in the rear (с 01.11.1963)
MB partsman
Silicon Valley
high spec....
what i would regard as 'extras':
673high-capacity battery (с 01.01.1964) <normal with air/con>
all the rest id expect on a standard 500sel......
in the 'good old days' 'options' <known as SA's> were all listed <SA = anything over a basic spec> nowdays only items over standard <for that model> are listed....
what i mean by that is a S280<W140> doesnt have self leveling as std... if one was built with it it would be shown as an SA, where as an S600<W140> has self levelling as std, so its NOT shown as an SA.... so as a partsman you NEED to know what every model, in every year has as a basic spec!
then.... you get imports....which may have a different basic spec..!
