CD Changer for a W210
rathbane4
West Yorks
I have recently purchased an E240 (W210), first registered in June 2000, which has a factory fitted MB Audio 10 CD ICE system. The unit has a CDC button to also select CDs from a CD changer unit, if fitted. I have contacted my local MB dealer in an attempt to establish if the car will be pre-wired to accept a CD changer, however, they were unable to confirm one way or the other.
Does anyone know if the cars are pre-wired and if I will need a security code to fit a CD changer. The unit I am considering to purchase is an Alpine 6 CD changer, which comes in two variants; for pre-wired or non pre-wired, hence the reason for my enquiry.
Best Regards,
Rathbane4
Best Regards,
Rathbane4
I have never known a car to be pre wired for a CD changer
Do take care in getting the right one,your year was a change over year to fibre optics
R
rathbane4
West Yorks
Thanks for the replies.
I have been advised that a boot mounted Becker or Alpine MC3198, is the cd changer I require. This model is fibre optic compatible and the car should be wired to plug and play?
Has anyone experience of fitting this model of unit?
Best Regards,
rathbane4
bobthe chef
Cork, Ireland.
E200 Estate(yr 2000) Seat Mpv
E200 estate ff cd changer
Recently purchased E200 estate with FF 10 cd changer ,does anyone know where the changer should be located and is the model fibre optic compatible (reg Aug 2000) and any thoughts on the brand to install Many thanks .
OlafMaxwell
Cork Ireland
W210 E320 CDI Estate
Bob, The changer unit is located behind the removable panel in the boot of the W210 estate, driver side. There is a recess below the general level of the boot and it sits on a mounting bracket in the void. Its well protected there. I have one fitted there but it was the MB option when the car was ordered. As far as I know the connection is fibre optic. However I must add that my 95 Peugeot 405 has a Peugeot labelled Clarion unit with a cd changer on which the sound is vastly superior to the Mercedes Audio 10 unit.
most "Yank Tanks" are malc ..............Marie has had 3 Grand Cherokee;s all pre wired for a CD changer!!!!
The MBs are not, my info covers the wide world.
I do have the fitting instructions
Myros
R107, S211, R170, C219
Malcolm
could I be cheeky and ask for the fitting instructions? I have one to fit in my 210 now, and would like to able to do it without reverse engineering from the mem's.
bobthe chef
Cork, Ireland.
Go Rabh matha gath Olaf i would have still been looking cheers Bob the Chef
