barry jones
- Oct 7, 2008
- Location
- Warrington
- 2016, LWB W222 AMG Line S-Class S350d - W415 Citan Van too :)
Hello all....
Having fitted the CD Changer and phone kit from a 2002 into my 2003 facelift S Class and getting it all to work.... I finally got round to trying it today for a proper go!
I need to buy the S Class phone microphone because although everything works, the microphone is an add on which mine hasn't got and I now need to order!
Anyway, previously I have sat in the car and tried the CD Changer and worked through the tracks with the steering wheel controls and everything has worked fine. I have never really used it on the road until today. I drove out and put the cd changer on and everything was fine until I braked and then the changer cut out.
Strange I thought so I tried it again and sure enough the changer works well until I touch the brake pedal and it all goes off and then comes up with "NO CD CHANGER" on the radio display and NO CDC on the dash.
Now obviously I have spliced into the wrong wire somewhere but all of the splicing was done in the passenger footwell as per factory fit. Once I turn off ignition, remove key and then restart; it all works perfectly well until I brake again.
I have a feeling that it may be the ground wire that is wrong as I have removed the blue/black and it still happens, I have removed the red/black under the rear seat and it still happens. The red/black under the front passenger side turns off all power completel to the CDC so it may be that one and I haven't touched the ground wire yet as I can't get at it and it is dark!
It could also be the wake circuit up on the fibre ring (d2b) as only the cd changer and phone are affected and althoough the radio goes silent for a short time if I press the brake, it does come back on unlike the CDC and phone.....
So if anyone has any ideas as to what colours the brake circuit uses (so I can check what I have connected to) that would be great. Otherwise I will have to remove everything again and I don't fancy that!
Baz
Baz
