cd changer problems
mercman111
ledbury
2005 clk 350 petrol
i have a 53 reg w209 which has the cd changer in the glove box,the stereo is saying no mag when there is,it will not eject (the mag)i have tried diconnecting the batt for an hour no change
Stafford71
W208 320 Elegance
I'd say the mag is stuck during an eject cycle. I had an old e46 bmw that had the same issue. Removed the CDC stripped it down, a bit of grease on the eject mechanism all was good. Took about 1 hour from memory
Sent from my ONEPLUS A6003 using Tapatalk
M
mercman111
ledbury
2005 clk 350 petrol
whats the cdc
M
mercman111
ledbury
2005 clk 350 petrol
does anyone know which fuse it is and where its located i drive a 53reg w209,i have lost the radio now
M
mercman111
ledbury
2005 clk 350 petrol
the screen is blank
Botus
S500/2010/500
the screen is blank
is this connected via fibre optics (for the sound and menus)
does it have a reliable power feed
does the unit being fitted function
Stafford71
W208 320 Elegance
What was the issue. This may help others in the future
M
mercman111
ledbury
2005 clk 350 petrol
i plugged the cd changer in
Stafford71
W208 320 Elegance
Lol. Ok good fix
ronrak
CLK320/2004/v6
Fuse 20 in the Trunk... It is not a Blade Type Fuse... and I cannot find the fuse. Please let me know if you find one.
M
mercman111
ledbury
2005 clk 350 petrol
its in the car on the right side of dash
AndySlade
Tadley, Hampshire
C220 Diesel Estate, Sports Edition
The fuses are under a removable cover on the very end of the dash. You will need door open to access the panel to remove it. Search YouTube and you will find a video.
ronrak
CLK320/2004/v6
I need a repacement for fuse 20. It is not a blade type fuse. It has a sort of square plug on it. So you say there are spare fuses at the very end of the dash? There is a Fuse Panel on the very left side of the dash, but I don't see any Spare fuses in it?
AndySlade
Tadley, Hampshire
I indicated where the fuses were located, not spare fuses. Post a photo of what you mean’.
ronrak
CLK320/2004/v6
I’ll get a pic of the fuse. The plastic broke off but the shape of the plug is visible.
And The CD Changer fuse #20 is in the fuse panel in the trunk, not on the side of the dash Board.
ronrak
CLK320/2004/v6
This is a photo of the Plug end of the fuse. The plastic casing broke off when I was trying to get it out of the panel. 1652896271033.png
