cd/radio removal
scouse
between watford and spain
clk240
anyone got instructions how to remove, single cd becker unit from clk 230..2003 model..(209)...television did try you again but your mail box is full again... checked all fuses and are ok...but not comming on..on dash it says AUDIO.... (four dashes)..the middle consoul just clips out...ive taken that out...see stereo but i think its screwed down somewere...if it is coded how do i recode it?... at the moment the unit is dead...i think what i might have done is reset back to factory code when i reset oil change...thats all i done ...it started flashing..then radio come on...when i tried cd it flashed again...so i pulled fuse for unit in front of engine...hoping it might reset its self...now its completly dead.......as iam in spain...merc dealers are not to be found were i live.....phoned one but my spanish is not good enough...any help would be very usefull....thx..
No one has asked for the removal instructions but I will print it off this evening.
I have the instructions for you :D
I need an email address please, you can edit it out shortly
redrx7
Registered
Belfast
ML 270CDI
Audio 10
Looking to remove the Audio 10 from a 2003 Ml and replace it with a DDin Unit. However having read various the posts I'm now a little concerned as to whether the current Harness adapter CT10MC02 , is suitable for use with the D2B Bus Connections of the W163 .
Does anyone have direct experience of replacing this unit on a W163 and what steps were necessary to get full connectivity?
www.W140.co.uk&www.r129.co
