Cdi fuel problem
vito dazza
My vito 108cdi keeps 'running' itself out of fuel, the fuel delivery pipe that runs from the fuel filter to the pre pump is pumping a mixture of diesel and air, then after a minuet or two it stalls with nothing but air in the fuel pipe. Could this be the high pressure pump on it's way out?:(
I think that you will find that a leak in the fuel or return line can give this problem. there are many threads on the forum on solving the leaking pipes.
Malcolm
