central gateway
Keith Prole
SL350/2013/3.7
Hello i have a 2003 SL350 (R230) can anybody tell me the location of the central gateway and how easy it is to remove
any help would be very welcome thankyou
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Easy to remove, all you need is a screwdriver and a pair of wire cutters!
Getting over the amount of problems you would then encounter after the removal would be the difficult bit!
The Central Gateway is an essential part of the CAN-Bus installation and enables cross domain communication and connected services. The Gateway is the central communication node within vehicles. Several bus systems are connected to the Gateway. The Gateway distributes data securely between all bus systems and the outer world.
Why on earth would you ever want to remove one?
K
Keith Prole
SL350/2013/3.7
Hi Tony i came out to my car yesterday after 2 days of torrential rain all the dash lights kept coming on and going off
out side my headlights were flickering on and off when they were not switched on somebody told me its probably the cgw thats somewhere in the boot thats got wet and my boot was wet the foam that covers the pump was absolutely soaked thats why i posted this thread but having read your reply i think i will leave it just out of intertest where is it thankyou for your help tony very much appreciated have a nice day
Tony Dyson
God's Country
Hello Keith, I am not certain where it is on your model, guessing is only going to force you to unnecessarily dismantle your car piece by piece as it is a small item and can be hidden in the smallest of spaces.
What I suggest you do is take a step back, complete the missing details in the Your Account section, and post an introduction in the 'Introduce Yourself' thread, then repost on this thread with the full details of exactly what you have experienced to Date for the forum to respond to, it sounds like the problem could be a SAM rather than the CGW you have been advised but I'm sure others will add to this in due course.
Disconnect the pump in the boot. Any device on the CAN bus can cause issues around the car.
It can cause all those issues if it gets wet.
Do NOT close the boot lid while pump is disconnected.
Also make sure the boot unlocks correctly using the physical metal key before doing anything else.
K
Keith Prole
SL350/2013/3.7
Thankyou
K
Keith Prole
SL350/2013/3.7
thankyou i will try that have a nice day
Central gateway is front footwell. Unlikely to be the issue.
K
Keith Prole
SL350/2013/3.7
i have done what you said unplugged the pump i dried it all out reconnected it had a 50 mile drive all back to normal
thankyou so much for your help
Start saving. It's now a matter of time before the pump fails.
Corrosion will have started on the circuit board and it will sadly eventually fail.
If you've reassembled I'd lose the foam around the pump. It just creates problems.
I knocked up a mount in TPU for mine on a 3d printer. Not the greatest but it works well enough. Also find out where the water got in and fix it.
