central locking prob
horgantrevor
www.flickr.com
E220 CDI avantgarde c43//amg
i have a C180 class year 94
it has a spyball alarm when you lock the car from key phob , it locks and alarms it self but when you go to open it the alarm goes off but the doors (all of them )do not open , you have to open with the key then they all open .
can any one help this is my second last job then she will be running perfect
jberks
Malcolm will be able to tell you more, but I believe the alarm is wired to the vacuum pump (under the rear seat?) .
If as you say, the central locking is working fine, then I'd suspect an issue with the alarm/locking interface and it's simply not telling the pump to open the doors.
horgantrevor
horgantrevor
www.flickr.com
the alarm speaker which is under the bonnet was had some water in it i dryed it out and since then it wont work i might have a look again thanks
horgantrevor
horgantrevor
www.flickr.com
the pump is in the boot right hand side she is an early model w202 c class
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Is your remote locking key a Mercedes one? As these vehicles came with remote c/locking as standard from the factory and were fitted with a Scorpion Alarm, which can be troublesome. The Scorpion Alarm was intergrated into the standard fit remote locking. Has this alarm system ever worked correctly since you have owned the car?
Have you still got red & green L.E.D.'s in the rear view mirror? and possibly in the door or boot?
Does your key look like the one in this post?
http://forums.mercedesclub.org.uk/showthread.php?t=26895
horgantrevor
horgantrevor
www.flickr.com
it has a SPYBALL alarm when you lock the car from key phob , it locks and alarms it self but when you go to open it the alarm goes off but the doors (all of them )do not open , you have to open with the key then they all open .
THE KEY HAS NO BHOB ITS A SEPERATE UNIT
bigasotonuk
Southampton UK
If the central locking works with the key in the locks, this eliminates the car wiring/central locking. If there are no cables, broken dirty connections, dodgy/blown fuses in the alarm wiring I think you have a duff alarm control box.
If i remember correctly the control box/siren is the same thing on spyball alarm. Well it was on my M5.
Inspect the control box/siren the fault maybe obvious, possibly dry joint etc.
You use to be able to buy reconditioned ones or Spyball would repair yours for approx. £100 but this was a good few years ago now.
Try googling for a Spyball website, they still might offer the service or even trying on e-bay for a new alarm and just utilise the siren/control box.
Good luck, keep us posted.
horgantrevor
horgantrevor
www.flickr.com
thanks ill try that hopefully ill be able to fix it soon
ill keep you posted
