central locking pump on eclass 94 estate.please
230K
Belfast
E300TD/1998/3.0 Diesel
I think it is under the back seat drivers side.
230K
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Central locking pump
It's on the passenger side. To get to it, lift & remove the rear squab, pull up the kick plate (it pulls off upwards) and pull off the trim strip the goes from under the kick plate up the rear of the door opening. Tease off a few of the white plastic clips that hold the edge of the carpet then pull the carpet up. The pump's in a big block of foam about 4" in from the edge of the car. It's not very easy to get at!
Nick Froome
www.w124.co.uk
Bolide
www.w124.co.uk
C/L pump W124
jonnyb1 said:
Nick.do you mean back seat passenger side?
Yes. There's a barely-noticeable lump in the carpet which is the pump. If you squish it you'll find it compresses - that's the foam block the pump is encased in
Nick Froome
www.w124.co.uk
230K
Belfast
Sorry it is drivers side in the 210 and 201 and i thought it was drivers on 124
230K
jonnyb1
aldridge west mids
many thanks will check it for water ingress........once its stopped raining cheers
