northants124
- Jul 18, 2006
hi all ,i really need some help/advice breifly one of my rear electric windows was working back to front on both door and centre console switches (pressed up window moved down and pressed down window moved up) i took the door card off and changed the wires in the wiring block to mimic the wiring block on the other door , this fixed the switch problem and both switches now controll the window in the correct direction switched, however now when i lock the car from either driver or passenger door the window in question moves down aprox. 1" when i unlock the doors the same window moves down again another 1" , all of the other windows remain in their normal positions , any ideas?
