Centre caps
Capra
Capra
Gloucestershire
W204 2013 C350 CDI Pan roof
  • #22
Just found what looks like very similar AMG ones to my originals on Amazon £22.99 for 4 so ordered - 1 to use and 3 x spares...;) happy days, I will let you know the quality upon receipt. Will also use the Duck tape method and see how it goes as I’ve recently already done my wheels off clean and I can’t be bothered jacking the car up again!
Hi John, have you got a link for Amazon?
ZZZZ
If you have no joy with a Duck tape loop, you can try the same method I described here (for removal of a gearshift top badge) - post #10:
http://forums.mercedesclub.org.uk/i...ft-handle-top-badges-amg-and-roadster.168149/
Would need a bit more hot glue, if the surface is not flat, but will still come off clean, once you apply few drops of pure alcohol.
daveenty
The Frozen North :(
2019 AMG S Class Coupe
If the old ones are goosed, just drill an 1/8" hole in them, insert a self tapper and pull off with pliers...
Maybe as I’m working on an ipad I can’t seem to copy and past the link, but if you go on Amazon and enter Mercedes AMG wheel centre caps you will see them - £22.99 carriage free from someone called Mayfair
Cheers Dave- being the miserable Scot I am, since it’s only 1 I’m intent on removing intact if possible and repairing it at my leisure for another spare....I could just take the wheel off but I’m way too lazy this week
Capra
Capra
Gloucestershire
  • #28
DREAMER NO2
W124 2.6E M103 1989
om dont last long , looking at those above. You will be able to buy 5 sets with the cash it cost to but one original set from mb You have just been shafted for that price off amazon . Remove the old ones with out damaging the wheel .Drill two 1/16 holes in the old cap and make a pair of wire hooks to pull them out .
These look v similar and are less than half the price?
eBay item number:
172638639260
You are right, the link doesn’t work but if it’s the same ones I saw, there was £14.95 postage so worked out at £23.94 so 5p cheaper but I suspect with that freight charge I’d see them direct from HK in about 3 weeks!
See my other reply on freight charges my friend.....
And how does drilling 2 x 1/16” holes not damage the originals ?
