Ceramic do-da inside my Cat!!
mouldb
Hi All,
It would appear that my S320 CDI Cat is starting to give up the ghost! I have been informed that the ceramic fixture inside is broken, hence the tap tap noise under the car.
Has anyone bypassed their Cat or have any advice rather than spending £1100.00 ?
Ta,
Bruce.
eGuru
Northants
www.artguru.co.uk
C180 S204, S320 CDi
Bruce
I was told the same by MB. However local indie diagnosed fault as severed pipe on vacuum pump. Also, if it is the front Cat, I had a quote of about £700 including VAT and labour.
Jay
Parrot of Doom
Manchester
My advice is to remove the cat (and pipe), cut a hatch in the top of it (so it can't be seen by looking under the car), gut the cat material with a big screwdriver (wear a mask while doing so), empty the contents out, get a mate to weld it back shut, and put it back on the car.
I would like to know how the wire mesh cats work, having opened up the the box and removing the ceramic cat it would be good if one could put in a mesh cat. Its an easy job with an angle grinder to open up the box and weld it closed,I have done that.
Malcolm
mouldb
what about my emissions. Has anyone done this before.....
Cant answer that one being a diesel, don't know if someone else can. I will do a search on wire mesh cats, some sites had the exploded veiws.
Malcolm
mouldb
You Da Man Malcolm!:D
turnipsock
Port of Menteith
I'm in the process of replacing my exhast, apre cat, for the MOT. I can see into the cat at the moment, looks like a lot of cardboard in there. Let me know if I can be of help.
Parrot of Doom
Manchester
Doesn't matter on a diesel. Cats aren't required. So long as it passes the smoke test you'll be fine, and the best way to pass a smoke test is to give the car a ****** good ragging before you take it to the MOT centre, and make sure they test it while the engine is still nice and warm.
