chain tensioner
goosergus
Aveley,Essex
Hi all,
My sprinter 208d is rattling a bit and i have been informed it is the timing chain.
There is evicence of the chain having hit a rail (described to me as a guide rail or guard rail) that sits just above the chain. I have booked for the chain to be replaced.
However the damage to the rail is minute and i have heard of suggestions that the tensioner can get clogged with dirt and not work properly.
Any opinions on this?
Should i try cleaning the tensioner first and if so is it a job for myself with some advice from this forum or an expert only job.
Lastly, the mechanic i booked to replace the chain has said the chain will have a removable link which will allow him to "wind" the chain into place without too much dismantling of the engine but a slip on the cog would mean a great deal of work.
Is this a standard or desirable approach to fitting a chain?
Thanks in advance
First here is a link for a 117 not your engine but the principles apply.
The tension er can be washed out, with no problem and do bare in mind that any debris has gone into the whole oil system, so just replace the oil and filter when you are done.
If you would like the correct work sheets please just put up the first 6 VIN numbers
http://www.mercedesshop.com/Wikka/M117TimingChain
G
goosergus
Aveley,Essex
Thanks very much for the reply television.
VIN number wdb9023p9. Thats as much as i can remember till i get back to van tomorrow.
Thanks again
I have 3 papers for you,,it is the 601 engine, I am not sure if the visco fan is in the way, so I will include that.
I need an Email address you can put this up here and then delete it when I tell you in edit
IAN MAC
Clackmannan
I replaced the tensioner in my 310 last year, it started rattling when on a long run, been fine since. Think it cost about 60 quid and a doddle to do if you follow instructions.
Yes as Ian Mac, do take care its so easy to break a camshaft
IAN MAC
Clackmannan
At the price, i would fit new. No point messing with second hand parts. Just my opinion.
G
goosergus
Aveley,Essex
Sorry television, took a while but i have full VIN:
roadhog
Sunny Norfolk
W124 300D x2, C124 300
I would remove the VIN for now, television is erm, temporarily absent.
At least I hope it's temporary!
G
goosergus
Aveley,Essex
Cheers roadhog.
Hope telly is alright.
Anyone else got advice on cleaning out/replacing the chain tensioner on a sprinter 208d
roadhog
Sunny Norfolk
I would replace rather than clean, at the price it doesn't seem worth the effort.
G
goosergus
Aveley,Essex
Sorry i meant't advice on the how to rather than which. I don't want to get stuck in till i know what i am up against
G
goosergus
Aveley,Essex
Had the chain changed over weekend so had the mechanic change the tensioner.
I asked him whether he filled the tensioner with oil before fitting it and he said no as it fills itself. This is contrary to other advice i have read on other threads but is it okay to do his way.
The van has been on a run of around thirty miles and the slapping noise of the old chain has gone.
G
goosergus
Aveley,Essex
Yes but being as it wasn't primed properly do i need to remove it and prime it or will it have filled itself properly by now.
The engine sounds sweet enough!
technical01
could you please forward me the details on how to replace the chain, and also service
hi,.. having a noisey time right now,..sounds like the chain is on the way,.can you tell me how many degrees of stretch im allowed, and also the process for servicing the tensioner and also replacing the belt.
i have to do the head gasket so im not to concerned about joining the belts together,.unless there is another cheat!!1,..? lol
my email address is : daveabbott@hotmail.co.uk
thanks for any information that you can give me
engine no. 602 980
mercedes v-reg 310d
thanks again
