Change automatic transmission fluid
Status
Not open for further replies.
cng
I have a 94 E420 with automatic transmission. I would like to change the fluid but I do not have the right tool to take the drain plug out. None of my metric Allen style hex wrenches fit. Can someone tell me if this is just a simple metric Allen style hex plug and what size is it?
I try to use a vacume pump to suck the fluid out of the transmission, but I was only able to get one quart out with the pump.
JimmyTD
Northants
It's no good using a vacuum pump, it wont remove all the fluid.
You also need to remove the sump, change the filter and sump gasket and drain the torque converter to do a proper job.
As far as I can remember the plug is a standard size.
Status
