Hi, I recently had to change my cigar lighter fuse in the South of France. The location chart for the fuses was situated in the fuse box to the right of the dashboard beside the door closure. The tweezers were found in the rear fuse box on the rear LH wheel arch and the fuse I needed to change was under the bonnet in the black plastic box on the driver's side close to the bulkhead.
Can't remember the fuse no. but it was behind a relay and not at all easy to change - I needed the tweezers.
Hope this helps. BTW my car is a 2004 W203, hopefully the Y reg will have the same layout.
srry for my english... y fuse panel is under the hood in the right sight like the carbon fiter...just remove the cover and after that is antoher cover with clips... anyway i have a problem, i have a c180 komp 2002 and in the trunk i have fuse panel in the left where is the help box and get my nose the on the fuse and i switched some ... and i dont know if know is in the right posistion ..pls cant y make a pic of y fuse panel and send to me to check if is the same position.. thx
Comand Online Ltd is a specialist supplier of Mercedes Navigation Disks,
Phone & Bluetooth, iPod, DAB, CD and other COMAND retrofit parts to
enhance your vehicle.www.comandonline.co.uk
