changing discs
xvz1300royalstar
I need to change the front pads, discs and flexible hoses on my Vito 108cdi. I have changed the pads before but not the other items.
Anything I should be aware of or any tips regarding the discs and hoses?
Regards
Robert
Ellsy Tanners
Mars
Not to bad to do mate, You may need a impact screw driver to undo the screw that holds the disc on to the hub. Caliper and carrier comes off easy enough.
When changing the flexi hoses, tighten the caliper connection first, then you can attach the pipe end without twisting the flexi hose which is a no no. If it is twisted then undo at the pipe end and reposition.
Good luck
