turbopete
- Feb 4, 2009
- Age
- 49
- Location
- Spennymoor
- 2018 '18' Ford Edge tdci biturbo (sorry)
first raise rear of car, support securely (axle stands, ramps etc) and choch wheels. go under the car and locate the strainer and outlet hose, roughly above the diff. it should look like this (pic 1)
then remove the protective boot that covers the strainer. it just pulls off. slide it along the hose out of the way like this (pic 2)
at this point, i removed the end of the hose attached o the metal fuel pipe under the car to start the fuel draining.
remove the trims from inside the boot behind the rear seat. 2 clips under the carpet, 2 screws at the sides and it should slot out from the side trims and the metal lugs at the top. (pic 3 has trim, pic 4 with it removed)
undo the 13mm nuts holding the tank in at each side (pics 5 gives an idea of location)
