changing tyre from 195/65/15 to 195/60/15
TonyJones
MK
2003 S55 L AMG kompressor
As per title - is this an ok change ? I understand the speedo will be about 3% out based on the change.
Have been offered some w124 alloys where prev Owner has changed the tyres to the lower profile. Recipient car 230te with 195/65/15 tyres that need replacing!
Tia
They should be 205 x 65 to be correct
The 165 tyres give a sidewall height of 107.25 mm and the 196 x 60 gives 99mm,, yes you will under read on the speedo, but only by a little bit
T
TonyJones
MK
I thought the 205/65 where options, and only where 'sport ' suspension is fitted - well that's what my handbook says :)
The choice is yours, and it does not make much difference, just a touch wider
SQ_W211
W219 CLS55 AMG
Tia
Speedo will not go 3% out by changing the tyre profile from 65 to 60. Its only going to make a difference if you change the total diameter by significant amount.
you may loose a slight amount of comfort by reducing the tyre size but it will not be very noticable
Amo he has changed the diameter by changing the profile
SQ_W211
W219 CLS55 AMG
changing profile from 65 - 60 is going to change the diameter by 19mm. will that make 3% difference?
16mm thats just over ½ inch
I partly miss read the post sorry
SQ_W211
W219 CLS55 AMG
Perhaps it will make a difference but surely not 3%
SQ_W211
W219 CLS55 AMG
Ok lets stop the discussion then ha ha ha.
Hope you been well Malc, I have been busy with work so not been able to spend much time on here recently
Well that makes it all the nicer when you come back Amo:D We do miss you at times ;)
SQ_W211
W219 CLS55 AMG
Glad to hear it Malc......
The Pan Man
Warwickshire
2008 E 500 A/G Classic colour combination.
Chaps its all about the circumference. i.e. How far the wheel moves forward per 1 revolution. Do the maths, I was quite good at school but, that was 45 years ago.
antijam
Gloucestershire
2003 SLK320
Does look like it's 3% guys....
In one rev of the wheel the speedo thinks the car has travelled 1992mm.
On the new tyres it will only have travelled 1932mm ..... 3% less.
So the speedo will be optimistic by 3% which, assuming it was calibrated correctly to start with, is well within the legal tolerance of 0 to +10%.
(note that it is however greater than the 2.5% recommended by etyres)
Amo was right,,I even got that 19mm wrong :( I am going to bed and cry myself to sleep:(
antijam
Gloucestershire
2003 SLK320
Cheer up Malcolm. Just because you're feeling old, incompetent and useless doesn't mean the rest of us think so. :)
....Not all of us anyway. ;)
Thank you antijam,, just thinking on this, the difference between new and worn tyres is some 13mm and that must make a difference of 2%
antijam
Gloucestershire
2003 SLK320
Absolutely Malcolm - and even different makes of tyre of nominally the same size have slightly differing rolling radii.
So if you want to go for your best 0-60 time do it on worn (possibly to the point of 'slick' ) tyres. Not only will your speedo tell you you got there quicker, you actually will have got there quicker because of the lower effective gearing!
T
TonyJones
MK
  • #20
antijam, used a similar site to do the maths.. Speedo reads 70mph, actual 67.85.
Anyway have bought the wheels/tyres. Alloys are perfect with 7mm of tread on the tyres. All for £101 on ebay - better than spending at least double that for tyres:D
Anyone need some steel wheels with worn out tyres?
