bernardtam
- Mar 13, 2007
- Location
- Hong Kong
- 1997 W202 C230 Kompressor
My charge indicator light is on all the time when I drive the car. The problem just started from this morning. I drove it for about 60 km today and everything seems to be fine.
Tonight I check the battery and it is only 11.7 volts at rest then when I start up the car, it went down to 11.4 volts. When I press hard on the gas, the charge indicator lamp will go dim but still there, while at under 1,000 rpm, it is bright and on.
Oh I check the battery and the fluid level is ok, grounding of the battery is fine too.
What can be wrong ?? The Alternator ?? or sometime else ??
If it is the Alternator, is it easy to replace ?? Thanks for any advise !
