Chip Tuning
Adamki83
Mercedes E-class, 2005, E270CDI (2.7) + 1992 Mercedes 500SL (R129)
hi all!!
Been thinking about chipping my E270, I feel like there is more to give out the engine it’s a solid old lump and I just feel like it can do more!!
Does anyone have any recommendations on where to go? I don’t want ludicrous power just a little bit more, anyone have any good companies they have used in the past??
B king
notts, uk
C270 2003 cdi(gone) / E350 Sport/ C63 (sons)/GLC daughter
Hi Adam, I used to have a 2003 c270 cdi ( 170) . I fitted a plug n play chip box from DTUK, fitted in 10 mins , just plugs onto the common rail sensor and away you go, works fine , loads more torque, car feels much more lively,( still got it if your interested ..!? )
dbanbery
Huddersfield
1995 R129 SL500
When my dad had a c270cdi he fitted a “drake box” that had 10 power settings which was as previously mentioned plug and play into the rail sensor. Although on setting 10 it put the car into limp mode it was so powerful
Adamki83
Adamki83
Sounds interesting, what sort of increase do you get? As in can you really feel it? How much would you charge me for it??
Adamki83
Adamki83
Just had a look at these and they look insane the Monza took it too 246bhp!! That’s a massive increase!
dbanbery
Huddersfield
1995 R129 SL500
Yeah, just be aware that if you use it anywhere past 5 for a considerable amount of time and drive it hard it will bin the torque converter and the rest of the gearbox will overheat sometimes. My dad drive his 70k on one of those chips and it binned the box and torque converter after a set of injectors. Lol
B king
notts, uk
cant remember the figures exactly Adam, it was quite some time ago, but I think they claimed about + 35 bhp and around 500mn torque.....however, yes you can really tell the difference. It is adjustable via a small screw inside ( not switchable maps like the more modern) cost me £190 , how about £40 on approval..? if u like pay me , if u don't , just send it back . ?? BTW the claims regarding better mpg are bull, it confuses your trip computer.... basically they work by just throwing more fuel in.., where else does the power come from ..!
Adamki83
Adamki83
Yeah I did wonder how it increased MPG!! And £40 is great but I’ll have to wait until after my MOT first (just in case it doesn’t pass for some silly reason) I can get back to you on it though? My mot is Saturday coming up so it’ll be anytime after that if that’s okay?
B king
notts, uk
fine, I better see if I can find it in my garage..!!
Auto Addict
North Midlands
Blue Efficiency C Class Estate
You could always fit a rubber crankshaft, as everyone knows, builds up the compression ratio as the revs. increase.
B king
notts, uk
car sorted yet Adam .........??
V6Matty
Newark, Nottinghamshire
Personally I wouldn't touch a box as you can tell from above they just fool the ecu into dumping more fuel into the rail, have it mapped, I did with my 270, end result was 225bhp and about 100( maybe a few over 100) tourques. Ran the car with that map for 100k and not a single problem with injectors, rail, pump, torque converter or anything mechanical related.
B king
notts, uk
had the box on the motor for 8 years matty with no probs, beauty of the box , it can b removed in 5 mins, does the pretty much the same job. The more modern units are much more intuitive, reading fuel pressure, boost press, n rpm, with switchable maps, is there a real difference in the box shoving more fuel in or the ecu ..?
John Laidlaw
Wirral
Land Rover Discovery 4
I see MSL are selling tuning boxes now, theirs I would trust so I guess things have come on
V6Matty
MSL's box plugs into about 8 different places John so very different to the above box, kind of a generic map from MSL in a box
V6Matty
Some don't have issues but I still personally wouldn't touch a box, and yes massive amount of difference between what a proper map does compared to a box that fools the ECU
Capra
Gloucestershire
W204 2013 C350 CDI Pan roof
Maybe as they work with so many MB they know how to do this correctly and properly? If they would put that name behind it I would trust it, but not as much as if it was on the dyno. Don't know why, I know nothing about mapping etc.
Capra
Gloucestershire
I cannot find any details of a DIY box from their web site.
They are a reseller for RaceChip tuning. I'm waiting for a price. Still not 100% convinced, but we'll see.
V6Matty
What they did was take a Brabus box and take it to bits from a physical perspective and then a diagnostic perspective and pretty much backwards engineered them, used there own map in it so slightly more tweaked over a Brabus map but still very safe.
Think it was big Chris that ran it as a test on his CLS63 SB (bi turbo) for about a year during development and I know Acid used it on his previous C63 and an A45 before he modified them further
www.ckinsurance.co.uk
