CL 500 Door card - How do you remove it?
Will Barber
Cheshire
2012 CL500 (4.7L M278)
Can anyone tell me how to remove the door card on a CL500 please.
I have removed the rear stainless panel and retaining screws, the screw behind the SRS cover, but can't get the upper section of the panel to release from the door.
Is there some screws behind the wood seat control panel... and if there is, how do you remove the seat control panel without damaging it. I've tried to release it but don't want to force it.
God I wish someone would author a manual for this car!
Many thanks, Will.
I can send you the information
OK Will you can edit out your address.
All these door cards have a hook in the center in line with the armrest that stops the card from bending when you close a door, so the card has to lifted up when taking them off, when refitting it is better to have someone holding the door, as you have to push the card inwards quite hard so that this hook re engages in the slot as you push the card downwards, do make sure that the locking pin is in line with the hole for it.
brandwooddixon
Wolverhampton
S63 Coupe 2014
If you have a W215 CL500 then you need to remove an upper screw that is only visible through the door air vent.
You may need to open the door and shine a light in through the side in order to see the screw.
The airvent is easy to remove once done. It slots into place.
The seat control panel (wood trim) is removed as follows:
  • Looking from the top you'll note a sliding latch, push this across.
  • Lift the panel straight up. DO NOT pull forwards otherwise you'll break the clips and have to find a new panel!
  • Unclip the wiring connector. It's quite tight.
Once all of the other visible screws have been removed then, which I think that you've done. Gently pop the clips that hold the bottom and side edges to the door.
You'll need to lift the door card up to unclip the top edge.
Unhitch the door release handle at the back.
Craiglxviii
Cambs UK
Well following the very specific instructions got the seat control panel off. It also allowed me to drop one of the bottom edge clips straight down inside the door (they dovetail in) so at some point I will have to strip the door to get at it.
I have determined that the seat/ mirror control panel is loose, looks like it has some broken clips. I'm looking for the part no for drivers side RHD in burred walnut and found the following- can someone please tell me which is correct?
A2157200248
A2157202048
A 215 720 02 48 COVER BURLED WALNUT; RIGHT
A 215 720 20 48 COVER CHESTNUT; RIGHT
chest nut is very light, see alexanderfoti's SL for sale, that is chestnut.
Craiglxviii
Cambs UK
I've put a request into the breakers sites for one. £170 new!!
Craiglxviii
Cambs UK
That was from a German spare parts site, not MB!
Craiglxviii
Cambs UK
Bargain at half the price!!
