Cl500 2003
heer123
CL500 2003
I have Mercedes cl 500 2003 back is to high code 1525 fault in rear right circuit the plunger travel sensor is at 0 can’t adjust can somebody help please
Plunger travel sensor is an internal part of the strut I believe. Sadly that means a new rear strut.
If you're lucky it may be a bad connection on top of the strut but I wouldn't hold my breath.
H
heer123
CL500 2003
H
heer123
CL500 2003
Thank you for your advice I have found another strut will let you no soon if problem solved thanks again
Naraic
2005 CL500.
I've had the same on the offside front of my car for 5 years. My solution was an adjustable link to the level sensor...works a treat.
