CL500Wizard
- Feb 6, 2009
- Location
- West London
- CL500, 2 x Honda Prelude 2.2VTEC, Honda VFR400 (Bike) ... that's about enough, need to skim
Hi All
First of all, thanks for a great forum, loads of information and a good bunch of people
I've got a 2000/1 CL500 and all the lights (interior, brakes) are pinking at idle but get brighter when revving plus there is noise from the alternator - sounds like the bearings. Looking at the belt movement, all the pulleys look ok to the naked eye. Belt looks in good condition overall.
After a bit of reading, I'm going to do the before and after ignition voltage readings (with lights and sat nav etc off and on in various combinations with engine running)
I also read on the net that the failing Bosch voltage regulator in the alternator can cause this fluctation problem but with the bearing type noise I suspect it would possibly be more involved than just changing the regulator which looks like a straight forward job.
Just a few questions if you don't mind:
1. Is the alternator refurbable? If yes, what's the best approach? DIY - special tools required? If not, there are a few Bosch service centres not far, any highly recommended in West London area (heathrow and nearby)?
2. How does one check the belt tensioner? (where is it )
3. Should I hold on from a 400 miles return trip at the weekend? Doing about 20-30 miles daily on an average 40 mph speed.
3. At idle, there is a light engine vibration which is a lot less since the air filters change and MAF cleaning with Electric Contact cleaner from HellFrauds (thanks Parrot of Doom: http://forums.mercedesclub.org.uk/showthread.php?t=18298). MPG has improved as well, and there is finally steam and water coming from the exhaust!
4. Finally, is there a Service Manual (I love those, bedtime reading!!) available? Other than the above, I'd like to check the sparkplugs as well (they were changed at 68 miles, car is now 93K miles) and anything else which is easy to check from the ignition and air side of things plus the oil and filter change - pretty good at following the manuals and like DIY as much as possible on my cars.
This is my first Merc (& German too), being a Honda Nut for some years I've usually worked on all my Hondas myself (engine rebuilt once too which took a few weeks :lol but with the Merc I don't know yet how often I'd need to go to an Indie or MB; guess that will become apparent with time. However, for starters if you can direct me to a guide on changing/checking/refurbing the alternator and the tensioner it would be much appreciated.
Thanks in advance for any help.
Arslan
Arslan
