Hi all.
Just in having the rear tyres replaced on my 2004 CL500 when it’s just been discovered that the left side rear shock absorber is leaking fluid.
Can this be repaired or will I need a new shock, and if so will the ABC fluid need to be replaced too?
The right hand rear shock is dry although the rubber sleeve is damaged.
Any help would be much appreciated.
Many thanks.
Many thanks.
