cl500 suspension fuse location ?
matteb63
Abergavenny Wales
Cl 500s & CLS500 with LPG conversions
my 2002 cl500 has dropped its suspension on all corners and im hoping its little more than a fuse if i can locate it.......im guessing its more likely to be the pump but its worth a visit to the fuse box
I think this may all be tied in with your other problems, I do not think there is much in the way of fuses for this, but I will take a look
matteb63
Abergavenny Wales
Thanks we have two cl500s .one is 2002 with the heating ..CAN ..memory issue. the other one is a 2000 cl500 while i was away my partner told me the suspension had dropped on all four corners ..is there a way to test the pump?
The suspension switches are doing nothing .
I see now :D Could be a relay or something, I will post back soon :D
matteb63
Abergavenny Wales
ok so today i charged up the battery ,checked the fuses and had a look in the abc reservoir which looked low but then i don't know what full looks like as there is no obvious marker ..there is also some sort of metal filter attached....Anyways pressed the button and hey presto up rises the suspension..
I think it might be a good idea to change the fluid and filter ....Is there a procedure for this and also for power steering fluid change anyone...?
matteb63
Abergavenny Wales
It is best that I send you the instructions for this
matteb63
Abergavenny Wales
that would be really helpful thanks Malcolm
Email address please for a few mins,, you can edit it out
matteb63
Abergavenny Wales
Thankyou Malcolm
OK and sent,, you can edit out the address
