CL500 W215 Won’t Start
Nexo
England
Mercedes
Hi folks. My CL500 W215 won’t start. I have replaced both batteries but still no joy. Consumers power up ok but the engine won’t crank.
Fault codes are
Voltage Supply Of Component
CURRENT and
0868 Motor Electronics/Battery Voltage STORED
Too Low For ADC(P0607)
1108
The Voltage At Relay 'Circuit 87' Is CURRENT and
Too LOW. (P2505)
STORED
M16/6 (Throttle Valve
0224 Actuator) perform Throttle Valve
Adaptation. (P2176)
CURRENT and
STORED
Any help greatly appreciated
ajlsl600
france
Can u record then clear those codes? See wot happens when u try start after that?
N
Nexo
England
Mercedes
Thanks for your reply. Those codes are after I cleared all faults.
N
Nexo
England
Mercedes
Here are faults before I cleared anything
0272 Continuous
Camshaft
Adjustment(RIGHT):I
correct Position Of
The Intake
Camshaft(P0012)
2070 Component
B14 (Ambient
Temperature Display
Temperature Sensor)
Has A Short Circuit
To Ground. (P0072)
0522 Diagnosis Of
Tumble Flap Intake
Manifold':Open
Circuit Of Sensor
Lines/Tumble Flap
Shafts Stick In The
Nonactuated
Position.(P2006)
1207 Constant
Adjustment Of Intake
Camshaft Of Right
Cylinder Bank In
Direction
0868 Voltage Supply
Of Component Motor
Electronics/Battery
Voltage Too Low For
ADC(P0607)
CURRENT and
STORED
1108 The Voltage At
Relay Circuit 87 Is
Too Low. (P2505)
CURRENT and
STORED
0224 M16/6 (Throttle
Valve
Actuator):perform
Throttle Valve
Adaptation. (P2176)
CURRENT and
STORED
Craiglxviii
Cambs UK
Fault codes are
CURRENT and
1108
Too LOW. (P2505)
STORED
Adaptation. (P2176)
CURRENT and
STORED
Your list didn’t come out too well. It LOOKS like there is a crank position sensor fault plus a throttle valve actuator fault.
Either way around, where are you based? You may need to have the car recovered to a garage and you may need one with good knowledge of the pig awkwardness of the 215…
N
Nexo
England
Mercedes
Based in Ireland. I’m motor trade myself. The non start occurred after it was laying up for a long time and had flattened batteries.
ajlsl600
france
Pig awkward about right. Strange if all these faults are after batt change AND faults cleared? Currently bets are on crank sensor of harness to it.
I changed my w208 batt once and it somehow blew the maf and alt reg, I wonder if that's similar to wots going on here. I researched after my event and found it fairly common and accepted method to avoid it was to have load on batt before cranking on new batt.
N
Nexo
England
Mercedes
It just has 2 low voltage and throttle actuator faults after clearing
ajlsl600
france
OK now Google that benz fault code . Wondering if that's referring to pot on throttle pedal or, more likely given ur description actuator on throttle body.?
However if throttle actuator don't get signal from ecm which looks input from pedal pot maybe it gives that fault code.
N
Nexo
England
Mercedes
Solved
On further inspection it turned out to be a faulty relay in the engine fuse box.
Craiglxviii
Cambs UK
Solved
That makes sense, it was called up in your fault report:
Too LOW. (P2505)
ajlsl600
france
Wonder if start attempt on new full full charged bat fd relay?
Craiglxviii
Cambs UK
Naraic
2005 CL500.
Fault codes are
CURRENT and
1108
Too LOW. (P2505)
STORED
Adaptation. (P2176)
CURRENT and
STORED
Both batteries? Do you mean the key batteries? The batteries are not required in the keys to start the car.
Naraic
2005 CL500.
The W215 has only one battery...or am I missing something?
Craiglxviii
Cambs UK
Facelift models have two batteries I believe. Mine only had one.
Naraic
2005 CL500.
Mine is FL with one battery.
brandwooddixon
Wolverhampton
S63 Coupe 2014
W216 has 2 batteries, but I'm pretty certain that my W215 only had the one in the boot - a real if you had a power open/close boot and a flat battery!
