CL55 AMG - Intermittent Reving
richardN2O
Guildford, Surrey
CL55 AMG Kompressor
OK guys thinking caps on. The intermittent fault came back this afternoon. Turn key, engine rev's to 2000 and stays there, blip the throttle it revs to 3000 sometimes 4000 and stays there. Re-start, revs to 2000 again. On approx. the 10th re-start it went back to normal - phew and I was able to get home. The last time this happened nothing showed up on the STAR and just re-starting it restored it to normal.
I'll continue using it until the intermittent becomes more regular or constant, then hopefully we'll find the cause.
NW_Merc
Banned
Oop Norf
Mercedes W202
Idle control valve?
Incidentally has the fuel filter (or filters) been changed?
richardN2O
richardN2O
Guildford, Surrey
CL55 AMG Kompressor
Idle control valve?
Not to my knowledge, major service next spring.
It runs superbly 99.9% of the time and NEVER misses a beat, apart from this very intermittent starting issue.
WG M-B
North west london
C63 Wagon in black
Surely it can only be receiving an incorrect signal from the tps, or a fault with the throttle actuator?
Never come across this :confused:
A
andy@pcd-ltd
One thing that springs to mind is there is a T-piece under throttle body and this might be starting to crack and taking in unmetered air
richardN2O
richardN2O
Guildford, Surrey
CL55 AMG Kompressor
Already replaced the entire throttle pedal as the accelerator sensor failed a couple of weeks back
richardN2O
richardN2O
Guildford, Surrey
CL55 AMG Kompressor
ty, but surely it would run bad all the time with something like that. It runs too well lol
A
andy@pcd-ltd
It may only be a very small crack
The other thing which i think i mentioned last time you had problems is these engines also suffer with throttle body issues as well
WG M-B
North west london
C63 Wagon in black
I think with the heat the 55k engines generate in the engine bay, if there was unmetered air via a crack in a plastic pipe it would expand/ break pretty quickly.
I may be wrong though and it's a good shout!
Also worth noting that the ecu should pick up this via adaptation values.
