guv
- Mar 15, 2009
- Location
- KENT, UK
- CL600, BI TURBO 2004
my car suffered intermittant misfires shortly after buying it, and as I have been driving its gradually got better over the last few months, if I add any fuel cleaner, within around 10 mins the car starts to idle badly and shake.
its now running on esso fuel, and all seem well, apart from when I put my foot down, car pulls strong then around 4-5k gets another kick of power, I am getting no faults on the dash, and MB say its the coil packs, but I cant see both failing at the same time, and £1k as side seems alot for a guesstimate, the car was serviced prior to me getting it it, and I am wondering if incorrect spark plugs would have this effect, the car is pulling 500bhp on a rolling road, and the only think we noticed was a damaged pressure sensor coming from the l/hand charge cooler, I have since replaced this, while this pipe was off the turbos spooled but gave no power,
in the usa, there is a company that rebuilds these coil packs, for around £235 per side with lifetime warranty, I am sure there must be a UK company that can do this? as I said I dont mind changing the packs to see if it cures but not for a grand a side,
I have had the secondary water pump changed / system bleed due to high charge temps, as I was told this was causing the performance problem, now its the coil packs...
