CLC 200 wing mirror indicator issue
TM691
CLC 200/ 2009/ 2.1 diesel
Hi all, and thanks for the add and first time owning a Mercedes.
I have Mercedes Benz CLC200 diesel 2009 and I noticed my drivers side mirror turning signal is not working. The mirror itself folding and adjusting works. I suspect it could be a loose connection or need to replace the bulbs.
I have been looking online on how to remove the cover and the one found that’s close to my mirror (see pics for reference) is by prowing the mirror glass to gain access to the wing mirror indicator unit. Knowing my luck and heavy handed that I might crack the mirror. Is it easy to prow the mirror or is the an alternative way to gain access.
I assume they are LEDs and complete unit. Any recommendation where I could purchase the wing mirror indicator besides the dealer in the UK?
Many thanks
Hello and welcome,
Could be a broken wire in the door - 10 years of opening and closing...
T
TM691
Thanks I will have a look there
umblecumbuz
Wales and Gozo
The mirror has a string of led's. Rare that they should all go at the same time, so - as said - it sounds like a circuit break somewhere.
The mirror will dismantle without removing it from the door. If you need to do that to replace the led strip, just be aware that the style strip on the leading face of the mirror (the 'tongue' in your first photo) is also stuck to the led clear plastic moulding with double-sided tape and will need 'easing' off.
flowrider
SL500 (R230)
When this happened on my ML I needed a new wiring harness, MB charged me about £250 fitted.
bembo449
gainsborough , lincolnshire
I repaired a harness to one of these last year on an E class , it had broken all the wires in the cold weather so it is possible to fix one pal
T
TM691
Thank you for the heads up and sounds it’s going to be a headache if I have to replace led strip. I will start by checking if there is any damage to the wiring. Hope it’s just a loose connection.
T
TM691
Thank you
Trev1964
Lydney
CLS 250 cdi estate 2013
Pretty sure that's going to be a broken wire or 2 from the constant folding.
Had same problem on my R171 SLK.
Easy fix, if a little time consuming.
rf065
Grossbritannien
Happened on my CLK, new LED cured it. Taking the mirror glass out is very easy too, not a big job to fix.
T
TM691
Hi Trev1964 I have not yet looked at mirror but bought led strip indicator just in case. It’s a bit difficult to see through the gap between the mirror glass and casing. By squinting my eyes through the gap I can just make out the 2 cable connector at rear of the mirror glass towards the top. I have not picked the courage yet to prow the mirror glass of the casing as I have heavy hands
T
TM691
Hi rf065 you make it sound easy . Knowing my luck will have the mirror glass shattered.
I was looking at this YouTube video
where there are clips/ tabs to remove the mirror glass and then there’s this YouTube video
where you prow out the mirror glass. Both videos mirror style is close to mine.
Not sure if there is any difference between either prowing or trying to undo the clips/ tab behind the glass mirror
Steve'o
New Registration
2009 CLC200 Kompressor
Hi TM691,
Sorry to reply to such an old post, but have been scouring the internet to find the part number or somewhere to buy a replacement indicator lens strip (without having to go to the expensive dealer option). Can you tell me what you bought, maybe where from and what the item number was? I am struggling as W203 as a model number only ever turns up the old style mirror and lens, pre-facelift.
Thanks, Steve'o
umblecumbuz
Wales and Gozo
I bought mine from a German supplier. Much cheaper than MB. The led's are not separately replaceable as they are molded into the clear plastic indicator lens. You need the complete lens.
Straightforward job, but care needed.
sexypin69
CLC 2008 1.8
How do you actually separate the casing from the body.
Any pictures??
sexypin69
CLC 2008 1.8
The clc is completely different, it seems like it is an complete unit???
tesla6518
Fareham,Hampshire,UK
C200 aventgarde 2002 W203, SLK 230K, CLC180K , E230
Hi
You seem to know a lot about this mirror, in which case do you know how to remove the mirror cover.
tesla6518
Did you manage to remove the cover to replace the indicator unit or did you do in situ. if you removed the cover could you tell me how you did it
