CLC boot leaking
Andy.M
Rochester Kent
2014 GLA250 Premium Plus, Night, AMG Exclusive Leather, Driving Assistance Packs COMAND DAB HK Audio
This afternoon discovered the boot is quiet wet in the right hand corner nearest the rear light. Haven't had a chance to investigate yet but will tomorrow.
Any pointers on where to look for source of leak please?
No damp smells so think it's not been a long term thing - I hope!
On many Mercedes the actual stampings are poor, this leaves a burr around the stamping, I would unscrew the nuts and remove and use a sealer then replace the lamp
NW_Merc
Banned
Oop Norf
Mercedes W202
I would just remove the lamp, make sure the rubber seal is correctly seated and refit and see if it remedies the problem.
If there is a burr around the stamping, it will never seal, and the reason why its leaking, hence the sealer added,,,, If you try and remove the burr, then the rust could set in. :D
NW_Merc
Banned
Oop Norf
Mercedes W202
An opinion Malcolm, without seeing the car neither one of us can give a definitive answer. 'If' being the operative word. What if it isnt what you said...... I'd go with the simplest solution and see if it is seated properly first.
Thank you again for your very constructive reply, these faults are listed in WIS along with the remedy, thats what I post up here :D
Angeloj
Norwich
W209 CLK270CDI Avantgarde
Surely a drop of Jenolite would prevent this??
Frontstep
T210 320cdi
I would avoid cutting or grinding any metal, rust sets in very easily on these cars.
Sealing with Silicone etc is reversible if applied sensibly.
Yes indeed and correct, NW merc is allowed to post trying to put me down
By putting a thin bead all round the aperture, when you fit the lamp it will bed down and give a complete seal.
It is just no good tightening up the nuts as is, for there is a risk of cracking the very expensive lamp.
A
Andy.M
Rochester Kent
Thanks for replies. Been feeling too ill to go look today (sniff).
Are you saying it may well be the rear lamp assembly not seating properly?
Frontstep
T210 320cdi
Yes its a possibility and one of the easiest to fix.
Yes the lamps are normally held on with 4 nuts about 6 to 8mm
A
Andy.M
Rochester Kent
Thanks for the pointer, hopefully it's an easy fix. I'll let you know what I find.
A
Andy.M
Rochester Kent
Stange, I had a look today and it's all bone dry. removed the access panel and had a good look round with a torch and no signs of water ingress in there at all.
Will keep looking over the next few days/weeks and see if it happens again.
