Clicking sound centre console - C32 W203
mingblus3
I have a srange clicking sound going on, it's not really loud but you can certainly notice it when the car starts up and stationary. It's noticable at low speeds and i'm pretty sure it does it when hot or cold. Tomorrow i'll try and get some more info as to whether it speeds up as the car moves faster and if it's still doing it in reverse.
I've had a look around on the web and the only things I've come up with so far are heatshield issues where they sag. I'm hoping this is something relatively easy to fix, seeing as i've had nothing but problems so far.
Any one got any other suggestions?
Regards
Simon
MB Service Centre
Mansfield
www.mbservicecentremansfield.co.uk
A210 E320
Hi the 203 do get problems with the heater flap actuators< theres quite a few of these on your car though. What happes is where the plastic arm fits onto the motor theyy split and the motor still trys to tunn causing this noise< its one to check.
rob
M
mingblus3
When i say centre console it's coming from the armrest. Where you would normally find a handbrake except on a merc.
Is this then the parking brake cable where the clips are broken and it touches the prop shaft
M
mingblus3
It's worth a look so i will jack the car up tomorrow evening and have a look if I have time. I'm guessing the cable runs the length of the car alongside the shaft?
Simon
Simon
This is a well known fault
M
mingblus3
That's good to know. Cheers
Simon
M
mingblus3
Just thought i'd add my results after the drive to work.
It was not apparent when I started it up this morning. It became noticeable after about an hour when i was driving around town. The noise stops when the car stops moving, it starts immedaitely after moving forward, it does seem to speed up the faster I get but I can't be sure for certain, it's hard to hear it when accelerating due to the sound of the engine and exhaust.
Then you know what it is then :D:D
Avocado
I have a similar problem w/ clicking noise under center console....I looked under car but I don't see the parking brake cable.....Television, can you please be more specific? Thank you for the excellent info.......
Alex Crow
Super Suffolk
70s bathroom suite, give us a little more info, eg this noise is only when moving, gets faster with speed and gets better/worse depending which way you turn?
As Alex above Just a little more info please, and welcome to the forum
Avocado
My 2004 C240 makes a clicking noise from under the center console. Noise picks up with speed and goes away when car is not moving.
I think it might be the parking Brake cable as was mentioned earlier in this thread, When I jacked up the car to look under....I couldn't locate the parking brake cable to inspect it.
The noise is irritating, but does not seem to affect the performance of car...
I love this car....but the noise is making me crazy !!! LOL.....
Any help is MUCH appreciated !!!......................THANK YOU
rich.g.williams
Cardiff, South Wales
C200 Kompressor Coupe 2003
try leaving the parking brake lightly on as a test then see if noise is still there.
If not then its parking brake related if noise still there its less likely to be related to parking brake
if all else fails to locate noise consider getting a small microphone on a wire place it in various positions and record sound - that way you can find where noise is coming from and get some clues.
M
mingblus3
Just a quick update mine is still clicking and have not yet had time to look underneath the car. I've purchased a mechanics stethoscope for another job but reckon this could come in handy locating it.
star
Reading
Smart + others :)
you might have to remove the heat shield under the car to the rear of the gearbox and then you might see rub marks on the propshaft where the hand brake cable is touching.
