r129MAN
- Sep 21, 2006
- Age
- 67
- Location
- Holbury Southampton
- SL500-2004
Hope someone can help, I am unsure whether my climate contol is working correctly or not. Switching it on to auto initially and at a temp of 24 deg C all seems fine & hot air blows around the car and the cabin warms up, then after a while even though there are 2/3 bars indicating that the blower is on no air appears to be flowing anywhere, increasing temp still does not make a change, is it that the interior temp has reached its set point & therefore the air is directed elsewhere until a large temp drop is sensed by the system. If I switch it all off and wait a while ( 20-30 mins) then switch it on again then you can feel the warm air blowing again at the footwell or windscreen demister, when no air flows even if I turn on the windscreen demister and the fan indicates full flow no air comes out of the vents. Am I concerned about nothing and this is the way climate control works or could I have fault. If yes to a fault any ideas what the problem could be.
