The rear is 40 because this is the profile ratio. The ratio is a proportion of the width. So, to make both front and rear almost the same you have 45% of 225 (101.25) on the front and 40% of 245 (98) on the back. The rears are only 3.25 mm smaller as regards the side wall than the fronts.
