clk 2001 convertible window problem and others
bob c
I had a flat battery and managed to finally get into the boot and change it.Since this has been done I have no electric windows and the red switch for the roof is lit up all the time and the switch for the headrest has a red light on all the time as if it is faulty.elec wing mirror adjusters don't work.Initially all these things fixed itself after the car was running for 20 minutes but now it is always faulty.
Any help would be appreciated.
thanks
bob c
Hi Bob and welcome..
Your car needs a re set
Turn the key to 2.
Lower then raise each window and hold the switch for 10 sec in the up mode.
Do the same with the roll bar in the up and down mode.
thats it.
The roof cannot move until it knoews where the windows and roll bar are:D:D
B
bob c
How do you tell position 2.And does it matter that I cannot get the windows to move at all
at the moment.
thanks
Bob
On re reading, disconnect the battery again leave for 5 mins and try again
B
bob c
thanks very much.It all working again.
thanks
Bob
B
bob c
I came out the house this morning and it was back to the way it was.no windows and the electric roof switch on and red light on the headrest switch on.I tried disconnecting bat for 5 min and reconnecting and it reset it again.2 hours later it had went back to old fault.Any thoughts
Yes I am thinking possible water in electrics,,I think that the fault codes will have to be read out.
You can use a good indie.
Where are you based
B
bob c
I am based 18 miles south of Glasgow (Greenock).Would I have to reset the windows and headrest switch after connecting up the battery.
thanks
B
bob c
Clk Window Problem And Other
I have tried disconnecting the battery again,once again it cured the fault and the windows worked and the lights went out on the roof switch and rear seat head rests(safety bars) .I drove the car for 2 hours and it was fine turned the car off for 5 min went back into car and it was ok.The next time I turned the car off for a couple hours and tried it again and it was back to the original fault.no windows roof switch light on and rear head rest adj switch showing fault.
any ideas
thanks
B
bob c
clk 230 conv fault codes
I have had the fault codes read and they are as follows
1.c1140 sterring angle sensor
2.c1142 b24/2 ESP Acceleration Sensor
3.Airbag sensor drivers side resistance to low
4.B1091 Rollover Bar /soft top control Module
The last fault I am assuming is causing the main problems with the windows not working and the roof not working.
thanks
bob
