Hi everyone, This is my first time so please be patient !!
I,m desperate for some advice regarding an ongoing problem with my CLK200. Its only done 32000 miles and has always serviced properly by specialist garages using genuine Merc parts and quality oil .
I bought it 4 years ago with 13000 miles on the clock and its been brilliant up until now. Just before Christmas it started to clonk and jerk once presumably as the auto box changed down as you approached a junction. It didn't do it every time and sometimes it seemed as though the gear had not selected as you went to pull away. It then clunked as the drive took up. I was advised to replace the auto transmission oil with the geuine Mercedes transmission fluid also the filter. The old oil was clean as a whistle and apart from some minute carbon deposits in the filter there was no debris or swarf indicating any mechanical failures. The car now drives a lot smoother and the clunk/jerk has improved. I had the external transmission sensor with the "O" rings replaced with a new one even though it was not oil contaminated. The car was scanned, there were no suspicious fault codes that might indicate any gearbox problems. The MAF had recorded a fault in the past and the code was cleared, I was asked to drive the car for 200 miles or so we can see if the code returns and the MAF sensor needs replacing. Does anyone know if this is a MAF related problem or is it a gearbox problem? Its going back into be scanned on Thursday. As far as I know MAF is original and has never been replaced. I only use good petrol and the car is not modified in any way. Can you clean MAF sensors or shall I bite the bullet and replace it anyway. Thanks for taking the time to read this, sorry its gone on but I thought it better to include all the relevant information/symptoms.
Thanks , Regards
Thanks , Regards
