CLK 220 CDI 2004 Alarm keeps coming on
delbertone
Northerm Ireland
CLK 2004 270
Hi There
Could any body help me, its my first time posting a thread but the last couple of days I've been driving along and sometimes the alarm sounds for about 2 seconds this is only audio there is no visual. Has anybody ever come across this and any idea how I could remedy this.
Many thanks
Delbertone
Cole@MBS
www.mbssouthampton.co.uk
Welcome
You need a new siren! common fault im sorry to say!
Hello and welcome, and as SAM above the siren normally solves it
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Roughly about £68 from mercedes and half an hour to fit, remove the inner wheel arch lining on the passenger side and its at the bottom part of the inner arch, bit of a fiddle but easy enough for a DIYer.
jib
D
delbertone
Northerm Ireland
CLK 2004 270
Wow
That is some service I cant believe how quick that was thankyou so much for your advice I will switch that over asp
delbertone
Raff
East Anglia
W208 CLK200 Kompressor (192HP),VW Touareg V6 TDI
Hi All,
Just got the same problem on my CLK240, and have solved it based on the described procedure,however there was a slight problem with a torx screw which was securing the siren to a frame.The screw had a pin inside (why?). The siren was £75 + VAT at MB.
And finally, when closing/opening the sound comes along with flashing (i.e. 3 flashes, 3 bipps), which have never occured before. Is that normal, or is it an remaining error within the ECU?
Cole@MBS
Its the way the new siren works, just a update i guess, the reason for the pin, its a security bolt!!
Welcome to the forums!
