Clk 230k Developing Problems All At Once !
rapiscan
W215 CL500 2003 5000cc
Hi all, my 1999 230K CLK is suddenly displaying various problems after 3 years of faultless ownership,firstly i have the BAS and ABS warning lamps coming on occasionally,intermittently along with the "visit workshop" on the computer screen,the cars brakes work normally and well even the ABS which i tested by purposly skidding on quiet back road,i can feel the brake pedal pulsate,so im puzzled? Secondly when i attempt to accelerate the car loses power and struggles yet runs smooothly at normal low speeds and at idle...fuel starvation??? filter..pump???or something more ££££ ? yikes! Thirdly and lastly today upon starting up,as i turn the key the starter motor engaged and kept turning the engine ,even though i had released the key and the engine wouldnt start...left it a few moments and all is fine,started and drove normally? any help with any or all of my probs would be most welcome,thanks in advance ,Mal.
coopz
if it was me i would phone up my mobile electrical mechanic.to put his computer on it .i feel these problems are all related,and to treat any one without doing a system analysis would be a waste of time and £££
As it is only the BAS and ESP it could be just the brake light switch, but not sure if this affects the CLK but I will look it up later in the day
rapiscan
rapiscan
Thanks for your prompt advice,keep it coming please...in the meantime im going to get one of those OBD readers to find out what codes are being thrown up....once again thanks.Mal.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
"as i turn the key the starter motor engaged and kept turning the engine ,even though i had released the key".
This is normal once put in the start position, it will crank for a pre-determined time, my C43 does this too.
At least its on fault you hav,nt got anymore.
As its been said i think you will need to get it put on a diagnostic computer.
You could try disconnecting the battery but make sure you have the stereo code, you will need to reset the windows and turn the steering from lock to lock several times to extinguish the ESP light.
jimsinessex
Essex
2008 W209 CLK 320CDI Coupe
No worries, that is completely normal. You have an automated starting system. Turn the key and immediately release it, that starts the start sequence, when the car fires up the starter will disengage. If the car fails to start the sequence will shut down after a predetermined time delay.
Enjoy your 1999 CLK 230K, I have :)
Jim
