Pegbasher
Hi all,
Recently purchased a 2004 CLK 320 Avantgarde Cabrio.
Fully running and pretty much ok with a few issues which I plan to address over the coming weeks....
Issue I would like help with is the passenger headlamp, all working apart from dip (xenon) bulb.
Faults I've found are:
Dipped bulb not working - swapped bulbs and both work on right headlamp
Passenger side headlamp internal chassis/bulb mount wobbly and loose - broken or possibly level sensor not working:
Previously had a subaru which are prone to ballast unit failing so am assuming similar problem and that I have a non-working ballast unit??
Thoughts are new headlamp unit, new ballast or level sensor??
I have SDS but very new to it and would welcome any advice or suggestions
