ssilver
- Dec 12, 2003
- Age
- 56
- Location
- Coventry
- E220 Estate BlueTec 2016.
Hopefully someone out there can answer the following questions regarding the COMMAND system fitted to my recently purchased 2002 CLK 320 Coupe.
The COMMAND/SAT NAV system has the ability to connect a mobile phone to it, the sterring wheel controls can be used to answer/end calls and numbers/information can be stored and retrieved from the in car monitor. How do you connect a mobile phone to the system ? do you need additional bits to make it work ?
It also has the ability to watch TV on the monitor, but again I assume you need a module to do this ? where does this go and where can I get one from (other than from MB, which I would assume is quite expensive)
Your help on this, is appreciated in advance
