CLK 320 Convertible Leaking!
Shavenuw
Hi guys. Woke this morning to find the passenger front & rear footwells swimming with water. Looks like it came from somewhere behind the passenger glove box, close to an air-conditionin matrix. The water had ingressed from outside as there were pine needles in it. All looks OK under the bonnet. Any ideas on where it can be coming from? Thanks.
Yes it will be the heater air intake box drain holes blocked, it is a matter of removing the grill in front of the screen, and clearing out the drain holes in the bottom, this should be done sooner , rather than later as it can knock out the motoer regulator
