You're probably worrying needlessly then. Thinking back, my "old" C200 used to smell quite a lot. It had well over 100k on the clock but it never overheated or broke down. I'm jealous as I'd really love to get hold of a nice CLK320 coupe.
Hi all. Jim2 good point I only have minimal info. Ok the car has 86k mikes on it, temp gauge shows just over 80 and doesn't raise in traffic or when driving. The engine performs beautifully and is very smooth.
The smell comes when you accelerating hard but this is for a really short time. As an example 0-60 say 9 seconds whilst engine is up to temp and the hot smell is there yet drive for 20 miles under normal conditions and nothing.
Been under the bonnet and all looks fine. I can't see any leaks (apart from an old rocker cover oil leak which doesn't show any fresh oil). Car was serviced 2k miles ago in Dec last year and the dash says Oil level is correct. Radiator feels cool to touch when I reach down at the front yet the top "cross member if that the correct name" is hot to touch. This is the panel the bonnet latches into. Plus the top hose on the radiator feels hotter than the bottom hose.
Gearbox shifts really well. I think that's all I have for now. Sorry for the lack of info in my first post.
Yes, INMO, Get the MB iCarsoft V2 ( not the MB iCarsoft 11, which is the earlier model, and the one I have. The newer model was introduced 1 week after I had bought mine... ) You can order it from uk direct, who are official suppliers, and they will supply updates as they become available ( something which is not guaranteed with all supplier's ). Just follow the instructions that come with it, registration etc, download the data onto the supplied micro card, insert it into the scanner, and off you go. They are simple to use, plug it into the socket under the dash ( near the bonnet release) turn on the ignition, identify the model MB you have and select "automatic" or "manual" scan mode. Press "OK" and it will scan. After it has finished, you can go through each section to check for stored fault's and either delete them, or investigate further. It allow's you access to data stream's in each section too, but you cannot go too deep that you can do more harm than good.( At least I have not been able to go that deep) which is a good thing...it's a very usefull tool, but like all tool's, you need to know how to use them.That makes a lot of sense and funny you should mention icarsoft as I am looking at buying one this week. Are they as good as they look?
