TWOBARROWS
- May 3, 2010
- Location
- FLEET, HANTS, UK
- '87 500SL (For sale) '99 CLK rag top, 04 JEEP Gnd Cherokee
I don't believe this. 2 new Coil Packs, I drive to work, it starts running rough again so I stop & disconnect the connectors to isolate which cylinder is failing, it's #4, I have to stop at least 6 or 7 times on the way to work & back & it's always pot #4. Got home, took the new good working coil from pots 2 & 3 & put it in posn. #4 & 1, then put the previously good Bosch coil (originally from 4 & 1) in pos. #2 & 3 thinking these are all known good working coils that have been proven. It's still playing up, pot #2 now! This can't be a coil problem, I just don't believe I can have a new failing coil & a previously known good coil suddenly fail.
I have noticed that before the cylinder is switched off the car starts to run a bit rough, & now I am listening, I can hear a 'tinny pop' or two, I guess that is the misfire. Is there anyone out there who can help explain how this poxy ignition system works please & why it fails in this manner. I can only think that there is somehow a 'weaker' coil that somehow causes this symptom, although the coil itself is not at fault? HELP, PLEASE!!! !!!.
