CLK aerial replacement (early C209)
Zarniwoop
2002 CLK 270 CDI (W209)
Hi all
A neighbour's cat did this to the little stubby aerial that sticks out of the top of the rear window on my otherwise lovely 2002 CLK. Am pretty ****ed off as it was perfect before.
Does anyone know how I can replace this, and where I can get the part without it costing a fortune?
The ridges at the base make it look like it should unscrew, but it doesn't seem to want to shift. And when I Google for 'CLK antenna', nothing that looks like this comes up.
As always, any and all advice gratefully received.
Many thanks,
Martin
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
Part 60 in the EPC below.
It appears to unscrew or pull out from Part 40.
Part numbers appear if you scroll down.
The latest number just supersedes the previous one.
There are a couple on ebay but they are for the roof mounted antenna, not the rear screen.
Your main dealer should be able to order one for you but if its a part no longer available you may have to search Mercedes breakers such as Dronsfields with any of the 3 part numbers listed.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Fairly sure that antenna is for the cell phone not the car radio.
rifiki
Worksop
CLK W209 W121190B
My 05 CLK with Comand has no external antenna.
brandwooddixon
Wolverhampton
S63 Coupe 2014
Damn I can imagine that you're peeved at that.
I thought that only the convertibles had an external aerial, all others are part of the rear screen heater element.
In any case I guess that you'll have to coat the replacement in chilli oil to stop the cat eating it!
