CLK Antenna
barkie
Pretoria, South Africa
I had the misforune of bumping into my garage door afting driving my new (demo) CLK 350, 2006 for only two weeks.The shark fin antenna broke off. I found it difficult to get a quotation for a new roof mounted antenna from DC since the technical specs shows a different kind of antenna. However, they did order a replacement part for me. The question is whether the antenna will come with the coaxal type cable connected to it. It seems to be mounted on the antenna. Also, is is not possible to fix the cable and then mount the old antenna - it is not broken, the 2 cables connected to it have snapped.
I am looking at CLKs tonight it is a 209---? next 3 numbers please.
malcolm
The new antena will come with the leads attached, these must be fed down to the spitter on near side rear wing. Your car is a little to new for me but I yhink the answer is correct.
malcolm
B
barkie
The numbers are 209356. They are importing the antenna from Germany. I also thought that there must be a splitter box somewhere. Just hope that the correct part has been ordered.:???:
