CLK Convertible Door Rattle - Is there a cure?
Phillbro
Brixham, Devon. UK
SLK 200 2011, Mini Countryman.
I can't take it any longer, I thought I could put up with it but I can't. The drivers door on my CLK rattles when I go over bumps and potholes and as the roads are never going to get any better down here, I need to cure it. The rattle seems to come from the handle/lock area of the door and is worse with the roof down. Is it easy to remove the door panel and check out whats behind it? Does anyone know if I need any special tools to get the panel off without messing it up?
Hoping someone has done something similar.
A
andy@pcd-ltd
First thing to check before you take the door panel off.
Under the bottom of the door there is some rubber grommets pull them out there is four i think.
Under two of them there is the nuts that secure the window runners. See if these have come lose they are very prone to
P
Phillbro
Brixham, Devon. UK
Good call, will check before I do anything else.
