CLK doorlock
Mercfunder
kdvkadfl
I have a 2004 CLK 320 (W209).
Yesterday the pin on the doorlock pin on the passenger side has started jiggling up and down a couple of times when the remote is pliped.
The door lock still functions OK, locking and unlocking.
Any ideas what is causing this, is it damp on a switch?
Any help appreciated.:D
rf065
Grossbritannien
Common fault apparently, the bit inside the door needs replaced, can't remember the name though. door controller?
Russ
Yes,,spring broken inside the notor or rubber grommet sticking on the rod
